Rocker arm assemble 360 chrysler 1978
I need a new rocker assembly for a 1978 360 CID does anybody know a automotive part number so I can pick one up at NAPA or what engine I should tell them to refer to
1978 F-32 Knotty Playsure twin 350xl 270 Crusaders
EDMONDS WA
Teach a boy to fish and he will go hungry supporting his boat
http://s1123.photobucket.com/albums/l550/Larrys78/
larrys@wsconline.net
EDMONDS WA
Do you just need the rocker arm...or the shaft assembly? Bob can get you the parts you need here:
http://www.trojanboats.net/PriceLists/C ... ts%202.pdf
The 318, 340 are also interchangeable.
Rocker, right is PN 4100774. rocker left is 4100775
Shaft number is 2532149
Or, just call NAPA and ask them to look up what you need.
I haved a complete set of 318 head witn intack valve gear if it will work. Am not long for carrying it to the recycler. Heads had about 900 hours on them but block damage due to freezing.
